Já jsem nepsal nic o tom, že máš vytvořit nový tag head, ale že to máš vložit mezi před </head>
Tedy, že najdeš
a před vložís ten javascript a css
Použij tento overall_header.html
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}" lang="{S_USER_LANG}" xml:lang="{S_USER_LANG}">
<head>
<!-- INCLUDE ca_config.html -->
<meta http-equiv="content-type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="content-language" content="{S_USER_LANG}" />
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="imagetoolbar" content="no" />
<meta name="resource-type" content="document" />
<meta name="distribution" content="global" />
<meta name="copyright" content="2002-2006 phpBB Group" />
<meta name="keywords" content="" />
<meta name="description" content="" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF T_STYLESHEET_LINK -->
<link rel="stylesheet" href="{T_STYLESHEET_LINK}" type="text/css" />
<!-- ELSE -->
<style type="text/css">
{T_THEME_DATA}
</style>
<!-- ENDIF -->
<!--[if IE 7]>
<link rel="stylesheet" type="text/css" href="{T_THEME_PATH}/ie7.css" />
<![endif]-->
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
popup('{UA_POPUP_PM}', 400, 225, '_phpbbprivmsg');
<!-- ENDIF -->
function popup(url, width, height, name)
if (!name)
name = '_popup';
window.open(url.replace(/&/g, '&'), name, 'height=' + height + ',resizable=yes,scrollbars=yes,width=' + width);
return false;
function jumpto()
var page = prompt('{LA_JUMP_PAGE}:', '{ON_PAGE}');
var perpage = '{PER_PAGE}';
var base_url = '{A_BASE_URL}';
if (page !== null && !isNaN(page) && page > 0)
document.location.href = base_url.replace(/&/g, '&') + '&start=' + ((page - 1) * perpage);
* Find a member
function find_username(url)
popup(url, 760, 570, '_usersearch');
return false;
* Mark/unmark checklist
* id = ID of parent container, name = name prefix, state = state [true/false]
function marklist(id, name, state)
var parent = document.getElementById(id);
if (!parent)
eval('parent = document.' + id);
if (!parent)
return;
var rb = parent.getElementsByTagName('input');
for (var r = 0; r < rb.length; r++)
if (rb[r].name.substr(0, name.length) == name)
rb[r].checked = state;
<!-- IF ._file -->
* Play quicktime file by determining it's width/height
* from the displayed rectangle area
* Only defined if there is a file block present.
function play_qt_file(obj)
var rectangle = obj.GetRectangle();
if (rectangle)
rectangle = rectangle.split(',')
var x1 = parseInt(rectangle[0]);
var x2 = parseInt(rectangle[2]);
var y1 = parseInt(rectangle[1]);
var y2 = parseInt(rectangle[3]);
var width = (x1 < 0) ? (x1 * -1) + x2 : x2 - x1;
var height = (y1 < 0) ? (y1 * -1) + y2 : y2 - y1;
else
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.SetControllerVisible(true);
obj.Play();
<!-- ENDIF -->
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
body {
background-color: #000000;
</style>
<script>
// Tady nastavte pocet vlocek (ne více jak 40, bude to trhat)
var snowmax=35
// Nastavte barvu vlocek. Múžete tam dát tolik, kolik jenom chcete.
var snowcolor=new Array("#aaaacc","#ddddFF","#ccccDD")
// Písmo, které bude vytváret vlocky. Múžete tam dát tolik, kolik jenom chcete.
var snowtype=new Array("Arial Black","Arial Narrow","Times","Comic Sans MS")
// Zvolte písmenko co bude vytvaret vlocky (odporoucíme:*)
var snowletter="*"
// Zvolte rychlost (odporoucime od 0.3 do 2)
var sinkspeed=0.6
// Zvolte maximálny velikost vlocek
var snowmaxsize=22
// Zvolte minimálny velikost vlocek
var snowminsize=8
// Zvolte zónu snežení.
// Zvolte 1 pro celý snežení, 2 pro levou stranu
// 3 pro stred a 4 pro pravou stranu
var snowingzone=3
var snow=new Array()
var marginbottom
var marginright
var timer
var i_snow=0
var x_mv=new Array();
var crds=new Array();
var lftrght=new Array();
var browserinfos=navigator.userAgent
var ie5=document.all&&document.getElementById&&!browserinfos.match(/Opera/)
var ns6=document.getElementById&&!document.all
var opera=browserinfos.match(/Opera/)
var browserok=ie5||ns6||opera
function randommaker(range) {
rand=Math.floor(range*Math.random())
return rand
function initsnow() {
if (ie5 || opera) {
marginbottom = document.body.clientHeight
marginright = document.body.clientWidth
else if (ns6) {
marginbottom = window.innerHeight
marginright = window.innerWidth
var snowsizerange=snowmaxsize-snowminsize
for (i=0;i<=snowmax;i++) {
crds[i] = 0;
lftrght[i] = Math.random()*15;
x_mv[i] = 0.03 + Math.random()/10;
snow[i]=document.getElementById("s"+i)
snow[i].style.fontFamily=snowtype[randommaker(snowtype.length)]
snow[i].size=randommaker(snowsizerange)+snowminsize
snow[i].style.fontSize=snow[i].size
snow[i].style.color=snowcolor[randommaker(snowcolor.length)]
snow[i].sink=sinkspeed*snow[i].size/5
if (snowingzone==1) {snow[i].posx=randommaker(marginright-snow[i].size)}
if (snowingzone==2) {snow[i].posx=randommaker(marginright/2-snow[i].size)}
if (snowingzone==3) {snow[i].posx=randommaker(marginright/2-snow[i].size)+marginright/4}
if (snowingzone==4) {snow[i].posx=randommaker(marginright/2-snow[i].size)+marginright/2}
snow[i].posy=randommaker(2*marginbottom-marginbottom-2*snow[i].size)
snow[i].style.left=snow[i].posx
snow[i].style.top=snow[i].posy
movesnow()
function movesnow() {
crds[i] += x_mv[i];
snow[i].posy+=snow[i].sink
snow[i].style.left=snow[i].posx+lftrght[i]*Math.sin(crds[i]);
if (snow[i].posy>=marginbottom-2*snow[i].size || parseInt(snow[i].style.left)>(marginright-3*lftrght[i])){
snow[i].posy=0
var timer=setTimeout("movesnow()",50)
document.write("<span id='s"+i+"' style='position:absolute;top:-"+snowmaxsize+"'>"+snowletter+"</span>")
if (browserok) {
window.onload=initsnow
</script>
</head>
<body class="{S_CONTENT_DIRECTION}">
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<tr>
<td id="logorow" align="center"><div id="logo-left"><div id="logo-right">
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
</div></div></td>
</tr>
<tr>
<td class="navrow">
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> • <!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a> • <!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED --><a href="{U_REGISTER}">{L_REGISTER}</a> • <!-- ENDIF -->
<!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> • <!-- ENDIF -->
<a href="{U_FAQ}">{L_FAQ}</a>
<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- ENDIF -->
<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
</td>
</tr>
<tr>
<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ENDIF -->
<!-- ENDIF -->
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_INFORMATION}</div>{L_BOARD_DISABLED}</div>
<!-- ENDIF -->
<table width="100%" cellspacing="0">
<tr>
<td class="gensmall"><!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ENDIF --></td>
<td class="gensmall" align="{S_CONTENT_FLOW_END}">{CURRENT_TIME}<br /></td>
</tr>
</table>
<p class="searchbar">
<span style="float: {S_CONTENT_FLOW_BEGIN};"><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a></span>
<span style="float: {S_CONTENT_FLOW_END};"><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></span>
<!-- ENDIF -->
</p>
<!-- ENDIF -->
<br style="clear: both;" />
<!-- INCLUDE breadcrumbs.html -->
<br />
