PHPBB 3 beta 5
morasino
PHPBB 3 beta 5
Příspěvek od morasino » čtv 08. úno 2007 20:16:32
Snažím se na hostuju.cz to nainstalovat ale za bohat ot nejde.Poradi nekdo.Je to chyba hostingu?
Příspěvek od WhiteWolfSix » čtv 08. úno 2007 20:38:40
Príliš málo informácii si poskytol, takže neviem odpovedať na Tvoju otázku. Beta verzie mám nainštalované od ich prvých vydaní, takže s inštaláciou by problémy nemali byť.
morasino
in
Příspěvek od morasino » čtv 08. úno 2007 20:56:03
Instaluju to a na začátku se my tam ukáže toto
Installation compatibility
Before proceeding with the full installation phpBB will carry out some tests on your server configuration and files to ensure that you are able to install and run phpBB. Please ensure you read through the results thoroughly and do not proceed until all the required tests are passed. If you wish to use any of the features depending on the optional tests, you should ensure that these tests are passed also.
PHP version and settings
Required - You must be running at least version 4.3.3 of PHP in order to install phpBB. If safe mode is displayed below your PHP installation is running in that mode. This will impose limitations on remote administration and similar features.
PHP version >= 4.3.3:
Yes, Safe mode
PHP setting register_globals is disabled:
phpBB will still run if this setting is enabled, but if possible, it is recommended that register_globals is disabled on your PHP install for security reasons.
No
PCRE UTF-8 support:
phpBB will not run if your PHP installation is not compiled with UTF-8 support in the PCRE extension
Yes
mbstring extension check
mbstring is a PHP extension that provides multibyte string functions. Certain features of mbstring are not compatible with phpBB and must be disabled.
Function overloading:
mbstring.func_overload must be set to either 0 or 4
Yes
Transparent character encoding:
mbstring.encoding_translation must be set to 0
Yes
HTTP input character conversion:
mbstring.http_input must be set to pass
Yes
HTTP output character conversion:
mbstring.http_output must be set to pass
Yes
Supported databases
Required - You must have support for at least one compatible database within PHP. If no database modules are shown as available you should contact your hosting provider or review the relevant PHP installation documentation for advice.
Firebird:
Unavailable
MySQL with MySQLi Extension:
Unavailable
MySQL:
Available
MSSQL Server 2000+:
Unavailable
MSSQL Server 2000+ via ODBC:
Unavailable
Oracle:
Unavailable
PostgreSQL 7.x/8.x:
Unavailable
SQLite:
Unavailable
Optional modules
Optional - These modules or applications are optional. However, if they are available they will enable extra features.
zlib compression support [ gz, .tar.gz, .zip ]:
Available
Remote FTP support [ Installation ]:
Available
GD graphics support [ Visual Confirmation ]:
Available
XML support [ Jabber ]:
Available
Imagemagick support [ Attachments ]:
Cannot determine location. If you know Imagemagick is installed, you may specify the location later within your Administration Panel
Files and Directories
Required - In order to function correctly phpBB needs to be able to access or write to certain files or directories. If you see “Not Found” you need to create the relevant file or directory. If you see “Unwriteable” you need to change the permissions on the file or directory to allow phpBB to write to it.
cache/:
Found, Unwriteable
files/:
Found, Unwriteable
store/:
Found, Unwriteable
Optional files and directories
Optional - These files, directories or permission settings are not required. The installation system will attempt to use various techniques to create them if they do not exist or cannot be written to. However, the presence of these will speed installation.
config.php:
Found, Unwriteable
images/avatars/upload/:
Found, Unwriteable
morasino
a
Příspěvek od morasino » čtv 08. úno 2007 20:56:54
A dál to nejde objevuje se tam jenom test agin
Příspěvek od WhiteWolfSix » čtv 08. úno 2007 21:49:26
Problémom sú tieto zložky:
cache/:
Found, Unwriteable
files/:
Found, Unwriteable
store/:
Found, Unwriteable
Musíš ich nastaviť na chmod 777, aby bolo možné do nich zapisovať.
morasino
n
Příspěvek od morasino » pát 09. úno 2007 9:36:01
Moc díky
