aktualne to vypada takto:
Potreboval bych pomoci pridat druhe logo vpravo od ikonek v tmavem pruhu..
Nize je muj kod overall_header, snad je to spravny soubor.
Budu rad za kazdou radu co a kam vlozit - ztracim se v tom
Diky
<!-- INCLUDEPHP styles/stratos/template/styleswitcher.php -->
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}" lang="{S_USER_LANG}" xml:lang="{S_USER_LANG}">
<head>
<meta http-equiv="content-type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="content-language" content="{S_USER_LANG}" />
<meta http-equiv="imagetoolbar" content="no" />
<meta name="resource-type" content="document" />
<meta name="distribution" content="global" />
<meta name="copyright" content="2000, 2002, 2005, 2007 phpBB Group" />
<meta name="keywords" content="" />
<meta name="description" content="" />
<meta name="viewport" content="width=device-width, initial-scale=1.0" />
{META}
<title>{SITENAME} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF S_ENABLE_FEEDS -->
<!-- IF S_ENABLE_FEEDS_OVERALL --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_NEWS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_NEWS}" href="{U_FEED}?mode=news" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_FORUMS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_FORUMS}" href="{U_FEED}?mode=forums" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_TOPICS_NEW}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_TOPICS_ACTIVE --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_TOPICS_ACTIVE}" href="{U_FEED}?mode=topics_active" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_FORUM and S_FORUM_ID --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FORUM} - {FORUM_NAME}" href="{U_FEED}?f={S_FORUM_ID}" /><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS_TOPIC and S_TOPIC_ID --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_TOPIC} - {TOPIC_TITLE}" href="{U_FEED}?f={S_FORUM_ID}&t={S_TOPIC_ID}" /><!-- ENDIF -->
<!-- ENDIF -->
<!-- INCLUDEPHP rokbb.php -->
<!-- INCLUDEPHP styles/stratos/template/stratos.php -->
phpBB style name: stratos
Based on style: prosilver (this is the default phpBB3 style)
Original author: Tom Beddard ( http://www.subBlue.com/ )
Modified by: RocketTheme, LLC (C) Copyright. All rights reserved.
// <![CDATA[
var jump_page = '{LA_JUMP_PAGE}:';
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
var base_url = '{A_BASE_URL}';
var style_cookie = 'phpBBstyle';
var style_cookie_settings = '{A_COOKIE_SETTINGS}';
var onload_functions = new Array();
var onunload_functions = new Array();
<!-- IF S_USER_PM_POPUP and S_NEW_PM -->
var url = '{UA_POPUP_PM}';
window.open(url.replace(/&/g, '&'), '_phpbbprivmsg', 'height=225,resizable=yes,scrollbars=yes, width=400');
<!-- ENDIF -->
* Find a member
function find_username(url)
popup(url, 760, 570, '_usersearch');
return false;
* New function for handling multiple calls to window.onload and window.unload by pentapenguin
window.onload = function()
for (var i = 0; i < onload_functions.length; i++)
eval(onload_functions[i]);
window.onunload = function()
for (var i = 0; i < onunload_functions.length; i++)
eval(onunload_functions[i]);
</script>
<script type="text/javascript" src="{T_SUPER_TEMPLATE_PATH}/styleswitcher.js"></script>
<script type="text/javascript" src="{T_SUPER_TEMPLATE_PATH}/forum_fn.js"></script>
This is the begining of the full width section for UCP, MCP and similar. Remove it if you want to preserve sidepanel in UCP, MCP etc..
<!-- IF U_PROFILE_STYLE or U_MCP_STYLE or U_PRIVATEMSGS_STYLE -->
<!-- PHP -->
global $template, $config;
$template->assign_vars(array(
'STRATOS_MENUPOSITION' => "full",
'STRATOS_TABS' => false
<!-- ENDPHP -->
<!-- ENDIF -->
End of the full width for ucp.
<!-- IF ENABLE_WEBFONTS -->
<link rel="stylesheet" href="http://fonts.googleapis.com/css?family=<!-- PHP -->global $config; $font = str_replace(" ","+",$config['stratos_fontface']); echo $font;<!-- ENDPHP -->" type="text/css" />
<!-- ENDIF -->
<!-- INCLUDEPHP styles/stratos/template/less.php -->
<link href="{T_STYLESHEET_LINK}" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- IF STRATOS_LAYOUT_MODE eq 'responsive' -->
<link href="{T_THEME_PATH}/phpbb3-responsive.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- IF IE_VERSION eq '8'-->
<link href="{T_THEME_PATH}/css/master-ie8.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- IF IE_VERSION eq '9'-->
<link href="{T_THEME_PATH}/css/master-ie9.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- IF ENGINE eq '-webkit' -->
<link href="{T_THEME_PATH}/css/master-webkit.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<link href="{T_THEME_PATH}/print.css" rel="stylesheet" type="text/css" media="print" title="printonly" />
<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->
<link href="{T_THEME_PATH}/bidi.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- IF STRATOS_TABS -->
<link href="{T_THEME_PATH}/roksprocket/layouts/tabs/themes/default/tabs.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<link href="{T_THEME_PATH}/<!-- IF STRATOS_MAIN_BODY eq 'dark' -->dark<!-- ELSE -->light<!-- ENDIF -->-phpbb3.css" rel="stylesheet" type="text/css" media="screen, projection" />
<link href="{T_THEME_PATH}/small.css" rel="alternate stylesheet" type="text/css" title="A--" />
<link href="{T_THEME_PATH}/normal.css" rel="stylesheet" type="text/css" title="A" />
<link href="{T_THEME_PATH}/medium.css" rel="alternate stylesheet" type="text/css" title="A+" />
<link href="{T_THEME_PATH}/large.css" rel="alternate stylesheet" type="text/css" title="A++" />
<style type="text/css">
<!-- IF S_CONTENT_DIRECTION neq 'rtl' -->
<!-- IF AVATAR_POSITION == left -->
.postprofile {float: left; border-right: 1px solid;border-left:0 none; margin-left: -6px;width: 21%;}
.postbody {float: right;}
ul.profile-icons {margin-right: 40px;}
.online {background-position: 17% -1%;}
<!-- ENDIF -->
<!-- ENDIF -->
</style>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/html5shim.js"></script>
<!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/mootools-core.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/mootools-more.js"></script>
<!-- IF LOAD_TRANSITION -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/load-transition.js"></script>
<!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/gantry-totop.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/browser-engines.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/rokmediaqueries.js"></script>
<!-- IF IE_VERSION neq '8'-->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/mod_roknavmenu/rokmediaqueries.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rt_js/mod_roknavmenu/responsive.js"></script>
<!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/roksprocket/roksprocket.js"></script>
<!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/roksprocket/tabs.js"></script>
<!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/roksprocket/moofx.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/roksprocket/roksprocket.request.js"></script>
<!-- ENDIF -->
window.addEvent('domready', function(){ new Fx.SmoothScroll({ link: 'cancel', offset: {x: 0, y: -60}}); });
var RokScrollEvents = [], RTScroll = function(){
if (!RokScrollEvents.length) window.removeEvent('scroll', RTScroll);
else {
for (var i = RokScrollEvents.length - 1; i >= 0; i--){
RokScrollEvents[i]();
window.addEvent('scroll', RTScroll);
if (typeof RokSprocket == 'undefined') RokSprocket = {};
Object.merge(RokSprocket, {
SiteURL: '{ROOT_PATH}',
CurrentURL: '{U_INDEX}',
RokSprocket.instances.tabs = new RokSprocket.Tabs();
RokSprocket.instances.tabs.attach(141, '{"autoplay":"<!-- IF STRATOS_TABS_AUTOPLAY eq 'true' -->1<!-- ELSE -->0<!-- ENDIF -->","delay":"{STRATOS_TABS_DELAY}"}');
<!-- ENDIF -->
</script>
<!-- RokBox phpBB3 Code Start -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rokbox/rokbox.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/rokbox/themes/<!-- IF ROKBOX_THEME -->{ROKBOX_THEME}<!-- ELSE -->light<!-- ENDIF -->/rokbox-config.js"></script>
<link href="{T_TEMPLATE_PATH}/rokbox/themes/<!-- IF ROKBOX_THEME -->{ROKBOX_THEME}<!-- ELSE -->light<!-- ENDIF -->/rokbox-style.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- IF IE_VERSION eq '7' -->
<link href="{T_TEMPLATE_PATH}/rokbox/themes/<!-- IF ROKBOX_THEME -->{ROKBOX_THEME}<!-- ELSE -->light<!-- ENDIF -->/rokbox-style-ie7.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- IF IE_VERSION eq '8' -->
<link href="{T_TEMPLATE_PATH}/rokbox/themes/<!-- IF ROKBOX_THEME -->{ROKBOX_THEME}<!-- ELSE -->light<!-- ENDIF -->/rokbox-style-ie8.css" rel="stylesheet" type="text/css" media="screen, projection" />
<!-- ENDIF -->
<!-- RokBox phpBB3 Code End -->
h1,h2,li.header dt, li.header dd, h3,li.header dt a, body, input, button, select, textarea, .gf-menu .item, dl.codebox code, #wrap .module-title h2 a, #wrap .module-title h2, #wrap .readon {font-family: "{STRATOS_FONTFACE}", arial, serif !important; }
</style>
<!-- ENDIF -->
</head>
<body id="phpbb" class="section-{SCRIPT_NAME} {S_CONTENT_DIRECTION} logo-type-{STRATOS_LOGO_TYPE} background-overlay-{STRATOS_BACKGROUND_OVERLAY} background-type-{STRATOS_BACKGROUND_TYPE} header-overlay-{STRATOS_HEADER_OVERLAY} main-body-{STRATOS_MAIN_BODY} font-family-{STRATOS_FONTFACE} font-size-is-{STRATOS_FONTSIZE} logo-enabled-<!-- IF ENABLE_STRATOS_LOGO -->1<!-- ELSE -->0<!-- ENDIF --> menu-type-dropdownmenu typography-style-<!-- IF STRATOS_TYPOGRAPHY_STYLE -->{STRATOS_TYPOGRAPHY_STYLE}<!-- ELSE -->light<!-- ENDIF --> col12 forum-layout-{STRATOS_MENUPOSITION} phpbb3-{CURRENT_STYLE} layout-mode-{STRATOS_LAYOUT_MODE}">
<div id="rt-page-surround">
<header id="rt-top-surround" class="<!-- IF STRATOS_HEADER_OVERLAY eq 'light' -->rt-light<!-- ELSE -->rt-dark<!-- ENDIF -->">
<!-- IF ENABLE_STRATOS_TOP_MODULES -->
<div id="rt-top">
<div class="rt-container">
<!-- INCLUDE modules.html -->
<div class="clear"></div>
</div>
</div>
<!-- ENDIF -->
<div id="rt-header">
<!-- INCLUDE features/logo.html -->
<!-- ENDIF -->
<div class="rt-grid-<!-- IF STRATOS_SEARCH_POSITION eq 'top' -->7<!-- ELSE -->10<!-- ENDIF -->">
<div class="rt-block menu-block">
<!-- INCLUDE features/menu.html -->
</div>
</div>
<!-- IF S_DISPLAY_SEARCH and not S_IN_SEARCH -->
<div class="rt-grid-3 rt-omega">
<div class="rt-block nopaddingall">
<div class="module-surround">
<div class="module-content">
<form action="{U_SEARCH}" method="post" id="rokajaxsearch" class="blue">
<div class="rokajaxsearch fp-search nomarginbottom nopaddingbottom">
<div class="roksearch-wrapper"><input name="keywords" id="roksearch_search_str" type="text" title="{L_SEARCH_KEYWORDS}" class="inputbox" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->"
onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" /></div>
</div>
{S_SEARCH_HIDDEN_FIELDS}
</form>
</div>
</div>
</div>
</div>
<!-- ENDIF -->
<!-- ENDIF -->
</div>
</div>
</header>
<!-- IF ENABLE_STRATOS_SHOWCASE_MODULES -->
<div id="rt-showcase">
<div class="rt-showcase-pattern">
<div class="rt-grid-3 rt-alpha">
<!-- IF STRATOS_SEARCH_POSITION eq 'showcase' -->
<div class="rt-block {STRATOS_SEARCH_STYLE}">
<div class="module-title">
<h2 class="title">{L_SEARCH}</h2>
<!-- IF STRATOS_SEARCH_STYLE eq 'title5' -->
<span class="rt-bubble"></span>
<!-- ENDIF -->
</div>
<form action="{U_SEARCH}" method="post" id="rokajaxsearch" class="light">
<div class="rokajaxsearch">
<div class="clr"></div>
</div>
{S_SEARCH_HIDDEN_FIELDS}</form>
<a href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}"><span>{L_SEARCH_ADV}</span></a>
<br />
</div>
</div>
</div>
<!-- ENDIF -->
<!-- ENDIF -->
<!-- IF SHOW_STRATOS_COLORSWITCHER -->
<!-- IF STRATOS_COLORSWITCHER_POSITION eq 'showcase' -->
<div class="rt-block {STRATOS_COLORSWITCHER_STYLE}">
<h2 class="title">Preset Styles<!-- PHP -->global $template;echo '<span class="title-icon ' .getIconClass($template->_rootref['STRATOS_COLORSWITCHER_STYLE']). '"></span>';<!-- ENDPHP --></h2>
</div>
<div class="variation_chooser">
<span class="rt-desc">Select variation:</span>
<!-- INCLUDE features/colorswitcher.html -->
</div>
</div>
</div>
</div>
<!-- ENDIF -->
<!-- ENDIF -->
</div>
<div class="rt-grid-<!-- IF STRATOS_SEARCH_POSITION eq 'showcase' -->6<!-- ELSE -->9<!-- ENDIF --> rt-omega">
<div class="rt-block fp-roksprocket-features hidden-phone nomarginright nopaddingall" >
<div class="fp-showcase">
<div class="rt-demo-showcase-content">
<h2 class="title">{SITENAME}</h2>
<div class="subline">{SITE_DESCRIPTION}</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
<!-- ENDIF -->
<div id="rt-transition" class="rt-<!-- IF LOAD_TRANSITION -->hidden<!-- ELSE -->visible<!-- ENDIF -->">
<div id="rt-mainbody-surround">
<!-- IF ENABLE_STRATOS_FEATURE_MODULES -->
<div id="rt-feature">
</div>
</div>
<!-- ENDIF -->
<!-- IF ENABLE_STRATOS_UTILITY_MODULES -->
<div id="rt-utility">
<!-- IF SHOW_STRATOS_DATE -->
<!-- INCLUDE features/date.html -->
<!-- ENDIF -->
<!-- IF SHOW_STRATOS_FONT -->
<!-- INCLUDE features/fontsizer.html -->
<!-- ENDIF -->
</div>
</div>
<!-- ENDIF -->
<!-- IF SHOW_STRATOS_PATHWAY -->
<div id="rt-breadcrumbs">
<div class="rt-block">
<div class="breadcrumbs">
<span><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></span>
</div>
</div>
</div>
</div>
<!-- ENDIF -->
<!-- IF ENABLE_STRATOS_MAINTOP_MODULES -->
<div id="rt-maintop">
</div>
</div>
<!-- ENDIF -->
<!-- IF ENABLE_STRATOS_FULLWIDTH_MODULES -->
<div id="rt-fullwidth">
</div>
<!-- ENDIF -->
<div id="rt-main" class="<!-- IF STRATOS_MENUPOSITION eq 'right' -->mb9-sa3<!-- ENDIF --><!-- IF STRATOS_MENUPOSITION eq 'left' -->sa3-mb9<!-- ENDIF -->">
<div class="rt-grid-<!-- IF STRATOS_MENUPOSITION eq 'full' or STRATOS_MENUPOSITION eq 'fluid' -->12<!-- ELSE -->9 <!-- ENDIF --> <!-- IF STRATOS_MENUPOSITION == left -->rt-push-3<!-- ENDIF --> rt-<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->omega<!-- ELSE -->alpha<!-- ENDIF -->">
<!-- IF ENABLE_STRATOS_TOP_PANEL or (STRATOS_TABS_POSITION eq 'top' and STRATOS_TABS) -->
<div id="rt-content-top" class="<!-- IF STRATOS_BODY eq 'dark' -->rt-dark<!-- ELSE -->rt-light<!-- ENDIF -->">
<!-- IF ENABLE_STRATOS_TOP_PANEL -->
<div class="rt-grid-9 rt-alpha rt-omega">
<h2 class="title">Welcome {S_USERNAME} !</h2>
</div>
<div class="module-content" <!-- IF not S_USER_LOGGED_IN -->style="margin-bottom: -4px;"<!-- ENDIF -->>
<div style="float: left;padding-right: 50px;">
<!-- IF USER_AVATAR --><div class="showcase_avatar"><a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{USER_AVATAR}</a></div><!-- ENDIF -->
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN --> <!-- IF S_DISPLAY_PM --><strong>You have: </strong> <a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><br />
<!-- ENDIF --> {CURRENT_TIME} <!-- ELSE --> {SITE_DESCRIPTION}<br /> <!-- ENDIF --> <br />
</div>
<div>
<!-- IF U_MCP -->[ <a href="{U_MCP}">{L_MCP}</a> ] <!-- ENDIF --> <!-- IF S_USER_LOGGED_IN --><!-- IF U_MCP --><br /><!-- ENDIF --> <a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l" >{L_LOGIN_LOGOUT}</a><!-- ELSE --> <a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a> or <a href="{U_REGISTER}">{L_REGISTER}</a><!-- ENDIF -->
</div>
</div>
</div>
</div>
</div>
<!-- ENDIF -->
<!-- IF STRATOS_TABS_POSITION eq 'top' -->
<!-- INCLUDE roksprocket/tabs.html -->
<!-- ENDIF -->
<!-- ENDIF -->
</div>
<!-- ENDIF -->
<div class="rt-block component-block">
<div id="rt-mainbody">
<div class="component-content">
<!-- IF ENABLE_STRATOS_FORUM_NAME -->
<h1 class="title">
<!-- IF FORUM_NAME -->{FORUM_NAME}<!-- ELSE -->{PAGE_TITLE}<!-- ENDIF --> </h1>
<!-- ENDIF -->
<div id="wrap">
<a id="top" name="top" accesskey="t"></a>
<div id="page-header">
<div class="navbar">
<div class="inner">
<ul class="linklist leftside">
<li class="icon-ucp">
<!-- IF S_ALLOW_JMENU -->
<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{L_PROFILE}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --> •
<a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a>
<!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --> •
<a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a>
<!-- ENDIF -->
</li>
</ul>
<!-- ENDIF -->
<ul class="linklist rightside">
<li class="icon-faq"><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li>
<!-- ENDIF -->
<!-- IF not S_IS_BOT -->
<!-- IF S_DISPLAY_MEMBERLIST --><li class="icon-members"><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><li class="icon-register"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<li class="icon-logout"><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="x">{L_LOGIN_LOGOUT}</a></li>
<!-- ENDIF -->
<!-- ENDIF -->
<!-- IF U_EMAIL_TOPIC --><li class="icon-email"><a href="{U_EMAIL_TOPIC}" title="{L_EMAIL_TOPIC}" class="sendemail">{L_EMAIL_TOPIC}</a></li><!-- ENDIF -->
<!-- IF U_EMAIL_PM --><li class="icon-email"><a href="{U_EMAIL_PM}" title="{L_EMAIL_PM}" class="sendemail">{L_EMAIL_PM}</a></li><!-- ENDIF -->
<!-- IF U_PRINT_TOPIC --><li class="icon-print"><a href="{U_PRINT_TOPIC}" title="{L_PRINT_TOPIC}" accesskey="p" class="print">{L_PRINT_TOPIC}</a></li><!-- ENDIF -->
<!-- IF U_PRINT_PM --><li class="icon-print"><a href="{U_PRINT_PM}" title="{L_PRINT_PM}" accesskey="p" class="print">{L_PRINT_PM}</a></li><!-- ENDIF -->
</ul>
</div>
</div>
<!-- ENDIF -->
</div>
<a name="start_here"></a>
<div id="page-body">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) -->
<div id="information" class="rules">
<strong>{L_INFORMATION}:</strong> {L_BOARD_DISABLED}
</div>
<!-- ENDIF -->
