mod
Re: mod
diki pekne.
no potrebujem poradit. po nainstalovani mi tam vypisuje takuto chybu, neviete co moze byt zle??
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2 [1064]
SQL
SELECT attach_id, topic_thumb, physical_filename FROM phpbb_attachments WHERE topic_id =2230 && topic_thumb = 1 && post_msg_id =
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: viewforum.php
LINE: 707
CALL: dbal_mysqli->sql_query()
Re: mod
Skontroluj si upravu viewforum.php
Zadal si SQL ktory je na konci install.xml -yourDBname zmenis za nazou svojej db
ALTER TABLE `phpbb_attachments` ADD `topic_thumb` TINYINT( 1 ) UNSIGNED NOT NULL DEFAULT '0';
ALTER TABLE `phpbb_forums` ADD `forum_topics_thumb_choice` TINYINT( 1 ) UNSIGNED NOT NULL DEFAULT '0';
INSERT INTO `yourDBname`.`phpbb_config` (`config_name`, `config_value`, `is_dynamic`) VALUES ('img_max_tthumb_width', '0', '0');
INSERT INTO `yourDBname`.`phpbb_config` (`config_name`, `config_value`, `is_dynamic`) VALUES ('img_min_tthumb_filesize', '0', '0');
INSERT INTO `yourDBname`.`phpbb_config` (`config_name`, `config_value`, `is_dynamic`) VALUES ('tthumb_req_upload_width', '0', '0');
INSERT INTO `yourDBname`.`phpbb_config` (`config_name`, `config_value`, `is_dynamic`) VALUES ('tthumb_req_upload_height', '0', '0');
Re: mod
Skus pohladat tvoj problem tu http://www.phpbb.com/community/viewtopi ... 5#p4664585
Este mozes mat iny prefix phpbb_ tabuliek nie ten co si daval SQL
Ta modifikacia je ABD je to opustený mod a podporu ti ktomu asi neposkytne nikdo
Re: mod
zrusil som ten nainstalovany mod vsetko som skopiroval naspat do povodneho stavu a teraz ked chcem presunut nejake forum tak mi vypise takuto chybu. pls nejaku radu so s tym??
Všeobecná chyba
Unknown column 'forum_topics_thumb_choice' in 'field list' [1054]
SQL
UPDATE phpbb_forums SET parent_id = 1707, forum_type = 1, forum_status = 0, forum_parents = '', forum_name = 'Battlefield 3', forum_link = '', forum_desc = '', forum_desc_uid = '', forum_desc_options = 7, forum_desc_bitfield = '', forum_rules = '[center:24jse7w1][img:24jse7w1]http://top-hry.sk/battlefield3banner.jpg[/img:24jse7w1][/center:24jse7w1]', forum_rules_uid = '24jse7w1', forum_rules_options = 7, forum_rules_bitfield = 'CAAB', forum_rules_link = '', forum_image = '', forum_style = 0, display_subforum_list = 1, display_on_index = 0, forum_topics_per_page = 0, forum_topics_thumb_choice = 0, enable_indexing = 1, enable_icons = 0, enable_prune = 0, prune_days = 7, prune_viewed = 7, prune_freq = 1, allow_sta = 0, forum_evaluation = 0, forum_flags = 48 WHERE forum_id = 697
BACKTRACE
LINE: 163
FILE: includes/acp/acp_forums.php
LINE: 1250
LINE: 192
CALL: acp_forums->update_forum_data()
FILE: includes/functions_module.php
LINE: 507
CALL: acp_forums->main()
FILE: adm/index.php
LINE: 74
CALL: p_master->load_active()
Re: mod
Píše ti to, že to chce použít sloupeček z databáze 'forum_topics_thumb_choice' ve 'field list'
Promazal's cache a pročistil šablony stylů a cache prohlížeče?
Re: mod
Daj odkaz na forum? Mam dojem ze sa jedna o warez http://www.phpbb.cz/viewtopic.php?p=112007#p112007
