když vložím:
vyhodí to tohle:INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_enable', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_send_id', '2');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_subject', 'Welcome to our forums!');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_message', 'Hello, {USERNAME}!\n\nWelcome to {SITE_NAME}. You registered on {USER_REGDATE}. According to your input, your email is: {USER_EMAIL}.\n\n-Thank you for registering at {SITE_NAME}! ');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_preview', '');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('wpm_variables', '');
co mám tedy udělat? DěkujiChyba
SQL-dotaz:
INSERT INTO phpbb_config( config_name, config_value )
VALUES (
'wpm_enable', '1'
MySQL hlásí: Dokumentace
#1062 - Duplicate entry 'wpm_enable' for key 1
