danti
Příspěvek
od danti » sob 24. pro 2011 18:57:30
Na žiadosť užívateľa
matesfc obnovujem Zoznam podmienok pre phpbb...
Okopírované od
RMcGirr83
RMcGirr83 píše:Posted with permission from the original author, RMcGirr83. We will not give support on this article. It is posted for your information.
<!-- IF S_USER_LOGGED_IN --> If a user is logged in
<!-- IF S_USER_LOGGED_IN -->your content here (for users logged in)<!-- ELSE -->your content here (for viewing as a guest)<!-- ENDIF -->
<!-- IF S_REGISTERED_USER --> If user is logged in and not a bot
<!-- IF S_AUTOLOGIN_ENABLED --> If auto login is allowed
<!-- IF S_BOARD_DISABLED --> If board is disabled
<!-- IF S_IS_BOT --> If a bot
<!-- IF S_USER_PM_POPUP --> If pop up pm is on
<!-- IF S_DISPLAY_SEARCH --> If displays search
<!-- IF S_DISPLAY_PM --> If display a PM
<!-- IF S_DISPLAY_MEMBERLIST --> If display memberlist.php
<!-- IF U_MCP --> If Moderator
<!-- IF U_ACP --> If Administrator
<!-- IF S_IS_LINK --> If its a link
<!-- IF S_UNREAD_FORUM --> If forum is unread
<!-- IF S_READ_FORUM --> If forum is read
<!-- IF S_LOCKED_FORUM --> If forum is locked
<!-- IF S_LIST_SUBFORUMS --> If there is a list of subforums
<!-- IF S_SUBFORUMS --> If a subforum
<!-- IF S_IS_CAT --> If a category
<!-- IF S_IS_POST --> If a post
<!-- IF FORUM_ID --> Displays the code between the switches if the user is viewing a particular forum.
<!-- IF SCRIPT_NAME == "index" -->some content<!-- ENDIF --> (Others you can use, viewtopic,viewforum,memberlst,faq etc)
<!-- IF S_USERNAME eq "cisco007" -->Some content here<!-- ENDIF -->
Examples
Let's say you wanted something to show in an html file for registered users only, then you could use the following
Code: Select all
<!-- IF S_REGISTERED_USER -->Hello, welcome to blahblah.com<!-- ENDIF -->
Which will only show to registered users.
or
Code: Select all
<!-- IF FORUM_ID eq 2 -->Welcome to Forum Number 2<!-- ENDIF -->
Which will only show if the viewer is within Forum Id #2.
You can also combine the IF's
Code: Select all
<!-- IF FORUM_ID eq 2 and S_REGISTERED_USER -->Welcome to Forum ID #2 and you are a registered user<!-- ENDIF -->
Also, you can use the following operands as well
or ( || )
and ( && )
eq ( == )
You can use either the language ones (or, and, eq) or the other ones ( ||, &&, ==).
Remember each time you have a <!-- IF something --> statement you must also have an ending <!-- ENDIF --> statement, else you will get errors when the templating engine does it's stuff.
Příspěvek
od leschek » ned 25. pro 2011 19:23:18
Tady je český překlad, jestli to někoho zajímá. Doufám, že tam není moc chyb.
RMcGirr83 píše:Posláno s povolením originálního autora, RMcGirr83.
<!-- IF S_USER_LOGGED_IN --> Pokud je uživatel přihlášen
<!-- IF S_USER_LOGGED_IN --> Nějaký obsah (pro přihlášené uživatele)<!-- ELSE -->Nějaký obsah (pro nepřihlášené hosty)<!-- ENDIF -->
<!-- IF S_REGISTERED_USER --> Pokud je uživatel přihlášen a není bot
<!-- IF S_AUTOLOGIN_ENABLED --> Pokud je povoleno autopřihlašování
<!-- IF S_BOARD_DISABLED --> Pokud je fórum vypnuto
<!-- IF S_IS_BOT --> Pokud je uživatel bot
<!-- IF S_USER_PM_POPUP --> Pokud je zapnuto vyskakování oken u SZ (soukromých zpráv)
<!-- IF S_DISPLAY_SEARCH --> Pokud je zobrazeno vyhledávání
<!-- IF S_DISPLAY_PM --> Pokud je zobrazena SZ
<!-- IF S_DISPLAY_MEMBERLIST --> Pokud je zobrazen memberlist.php
<!-- IF U_MCP --> Pokud je uživatel Moderátor
<!-- IF U_ACP --> Pokud je uživatel Administrátor
<!-- IF S_IS_LINK --> Pokud je to odkaz
<!-- IF S_UNREAD_FORUM --> Pokud je fórum nepřečtené
<!-- IF S_READ_FORUM --> Pokud je fórum přečtené
<!-- IF S_LOCKED_FORUM --> Pokud je fórum zamčené
<!-- IF S_LIST_SUBFORUMS --> Pokud je tam seznam podfór
<!-- IF S_SUBFORUMS --> Pokud podfórum
<!-- IF S_IS_CAT --> Pokud kategorie
<!-- IF S_IS_POST --> Pokud příspěvek
<!-- IF FORUM_ID --> Zobrazí kód mezi vypínači (mezi IFama - pozn. překl.) pokud uživatel prohlíží konkrétní fórum.
<!-- IF SCRIPT_NAME == "index" -->Nějaký obsah<!-- ENDIF --> (Další, které můžete použít jsou viewtopic,viewforum,memberlst,faq atd) - Pokud má skript jméno
<!-- IF S_USERNAME eq "cisco007" -->Nějaký obsah<!-- ENDIF --> Pokud je uživatel cisco007
Příklady
V případě, že chcete něco zobrazit v html souboru jen pro registrované uživatele, můžete použít následující
<!-- IF S_REGISTERED_USER -->Nazdar a vítejte na blahblah.com<!-- ENDIF -->
Což budou moci vidět jen registrovaní uživatelé.
nebo
<!-- IF FORUM_ID eq 2 -->Vítejte ve fóru č. 2<!-- ENDIF -->
Budou moci vidět jenom uživatelé, kteří jsou na fóru s Id #2.
IFy je také možno kombinovat
<!-- IF FORUM_ID eq 2 and S_REGISTERED_USER -->Vítejte ve fóru č. 2 a jste registrovaný uživatel<!-- ENDIF -->
Můžete také použít následující operandy
or ( || )
and ( && )
eq ( == )
Můžete buď použít jazyk (or, and, eq) nebo tyhle značky ( ||, &&, ==).
Pamatujte, pokaždé, když máte <!-- IF něco --> podmínku, musíte mít i ukončovací <!-- ENDIF --> podmínku, jinak dostanete chyby, když se budou zpracovávat styly.
Příspěvek
od leschek » úte 04. zář 2012 12:10:55
Trošku jsem experimentoval s podmínkama a zdá se, že potřebuju poradit. Chci aby se něco zobrazilo (obrázek v headeru) jen na určitých fórech např.: id 2, 4 a 6. Zkusil jsem s jedním fórem
<!-- IF FORUM_ID == "2" -->kód pro zobrazení obrázku<!-- ENDIF -->
a funguje to.
Pak jsem zkusil zkombinovat fóra pomocí &&
<!-- IF FORUM_ID == "2" && FORUM_ID == "4" && FORUM_ID == "6" -->kód pro zobrazení obrázku<!-- ENDIF -->
a tohle nefunguje, takže jsem nakonec skončil s
<!-- ELSEIF FORUM_ID == "4" -->kód pro zobrazení obrázku
<!-- ELSEIF FORUM_ID == "6" -->kód pro zobrazení obrázku<!-- ENDIF -->
což funguje. Nicméně by mě zajímalo, jestli by (pro přehlednost) nešlo vložit ID všech tří fór do jednoho IFu. A pokud ano, tak jak.
danti
Příspěvek
od danti » úte 04. zář 2012 12:18:49
Vyskusaj
<!-- IF FORUM_ID eq 2 or FORUM_ID eq 4 or FORUM_ID eq 6 -->kód pro zobrazení obrázku<!-- ENDIF -->
Příspěvek
od leschek » úte 04. zář 2012 12:27:28
Vynikající. Děkuji moc. Funguje. Že tam mám dát "or" místo "and" by mě nenapadlo.
