Kamahl
Příspěvek
od Kamahl » pát 11. črc 2008 0:30:24
Dnes bol vydaný ďalší opravný balíček pre Olympus. Opravených bolo skutočne veľa chýb, dokonca aj jedna malá bezpečnostná chyba. Tu sa môžete dočítať viac po anglicky
http://www.phpbb.com/community/viewtopi ... &t=1059565
A tu sú zmeny:
- [Fix] Ability to set permissions on non-mysql dbms (Bug #24955)
[Fix] Fixed blank style on setups having no username defined within config.php (Bug #25065)
[Fix] Made the compress_tar class tolerate archives that do not properly have their archived contents listed (Bug #14429 / thanks to JRSweets for his patch)
[Fix] Moved topics should not count towards the number of topics in a forum (Bug #14648 / thanks to Schumi for his patch)
[Fix] Properly check for invalid characters in MySQL DB prefixes during install (Bug #18775)
[Fix] Bring the PostgreSQL backup system back to working order (Bug #22385)
[Fix] Update correct theme for cached styles in style.php (Bug #25805)
[Fix] Correctly determine safe mode for temp file creation in functions_upload.php (Bug #23525)
[Fix] Correctly sort by rank in memberlist (Bug #24435)
[Fix] Purge cache after database restore (Bug #24245)
[Fix] Correctly display subforum read/unread icons from RTL in FF3, Konqueror and Safari3+. (thanks arod-1 for the fix, related to Bug #14830)
[Fix] Added missing form token in acp (thanks NBBN).
[Fix] Do not remove whitespace in front of url containing the boards url and no relative path appended (Bug #27355)
[Fix] reset forum notifications in viewtopic (Bug #28025)
[Fix] corrected link for searching post author's other posts (Bug #26455)
[Fix] HTTP Authentication supports UTF-8 usernames now (Bug #21135)
[Fix] Topic searches by author no longer return invalid results (Bug #11777)
[Fix] Delete drafts and bookmarks when deleting an user. (#27585, thanks Schumi for the fix)
[Fix] Set last_post_subject for new topics. (#23945)
[Fix] Allow moving posts to invisible forums. (#27325)
[Fix] Don't allow promoting unapproved group members (#16124)
[Fix] Correctly fetch server name if using non-standard port (#27395)
[Fix] Regular expression for email matching in posts will no longer die on long words.
[Fix] Do not display ban message if direct call to cron. (thanks Dog Cow for reporting)
[Fix] Correctly display double-colon on special conditions within highlighted php source (Bug #26795)
[Fix] Increase storage capacity of titles/subjects due to specialchared content (Bug #25235)
[Fix] Catch invalid username wildcard ban (we do not support these) (Bug #29305)
[Fix] Fix (email)-domain checks for those having DNS prefixes set (Bug #29635)
[Change] Adjust truncate_string() to be able to adjust the maximum storage length.
[Change] Sort the tables at the database table backup screen
[Change] For determining the maximum number of private messages in one box, use the biggest value from all groups the user is a member of (Bug #24665)
[Change] Show email ban reason on registration. Additionally allow custom errors properly returned if using validate_data(). (Bug #26885)
[Change] Don't allow redirects to different domains. (thanks nookieman)
[Feature] Added optional referer validation of POST requests as additional CSRF protection.
[Feature] Added optional stricter upload validation to avoid mime sniffing in addition to the safeguards provided by file.php. (thanks to Nicolas Grekas for compiling the list).
[Feature] Streamlined banning via the MCP by adding a ban link to the user profile. Also pre-fills ban fields as far as possible.
[Feature] Added ACP logout to reset an admin session.
[Sec] Only allow urls gone through redirect() being used within login_box(). (thanks nookieman)
odporucam updatovat
Příspěvek
od ameeck » pát 11. črc 2008 7:53:37
Na server nahrána nová verze překladu. Opravuje toho poměrně hodně
Rovněž opraveny odkazy na stáhnutí všech ostatních balíků.
Tak už bylo aktualizováno i phpBB.cz
Kamahl
Příspěvek
od Kamahl » pát 11. črc 2008 10:31:12
zavidim tu moznost updatnut behom 10 min
pre mna to bude praca na 2 tyzdne, plus dalsich 20for zakazikov, ktori budu chciet updatovat tiez
Příspěvek
od ameeck » pát 11. črc 2008 11:29:47
Tentokrát jsem použil ten Automatic Update a ono to doopravdy funguje...jenom udělám manuálně templaty a jazykové soubory.
seqwence
Příspěvek
od seqwence » pát 11. črc 2008 11:31:32
No já to stejně budu muset dělat tak i tak celé manuálně... takže mám o zábavu postaráno
Endure to the end.
Tom@S
Příspěvek
od Tom@S » pát 11. črc 2008 14:24:45
nie si sam ale ja som musim pockat na mody, btw chris planujes upravit tvoj mod pre botov? Zapacil sa mi
christian
Příspěvek
od christian » pát 11. črc 2008 15:16:40
To tam zase něco měnili? Když koukám tu,tak to funguje normálně..
Tom@S
Příspěvek
od Tom@S » pát 11. črc 2008 15:52:52
tam potom super, ja som to nejak extra nepozeral tak ak su tam tie riadky tak je dobre
kto by mal zaujem o slovensky preklad taktiez je uz hotovy, posledne 2 verzie, nova a stara 3.0.1
kajak
Příspěvek
od kajak » pát 11. črc 2008 21:37:19
tak jsem to zkusil a nic.... jak jsem předpokládal... :(
v nabídce mám převod z phpBB 2.0.x i když mám phpBB 3.0.1 tak fakt nevim -- ??
Příspěvek
od ameeck » pát 11. črc 2008 23:57:16
Stáhnul si aktualizační balík?
Příspěvek
od smiesek » sob 12. črc 2008 6:00:53
já nikdy žádný jazykový soubor ani template soubor neupravovala, vždy jsem pouze nahrála instalační soubor a přehrála na novější verzi, jak mám tedy poznat, co kde mám v těch mnou 2 souborech změnit?
Příspěvek
od WhiteWolfSix » sob 12. črc 2008 6:10:02
Skús si porovnať originál súbor s novým súborom v pspade a ten Ti vyznačí zmeny v kóde.
Příspěvek
od smiesek » sob 12. črc 2008 6:17:38
takhle samé se s tím musím šušnit s template soubory?
To není někde vypsané?
Návštěvník
Příspěvek
od Návštěvník » sob 12. črc 2008 22:54:28
můžeš mi poradit zda toto forum jde použít na stránkách
http://www.rc-truck.7x.cz případně propojit aby se nechalo z uvedených stránek komunikovat? děkuji FRANC
