Problém s Job módom
Problém s Job módom
nainstaloval som podla navodu mod, vsetko som spravil dobre a pri otvoreni fora nabehuje toto:
http://img0.imgup.eu/screen.jpg
Kto vie tak poradte please
- seqwence
Re: Problém s Job módom
vykonal jsi SQL dotazy na DB, které jsou napsané v instalačním souboru?
Endure to the end.
vykonal, vsetky. Bolo tam:
ja som dal do dotazov :
#-----[ SQL ]------------------------------------------
# Only do these SQL queries if you can not run the mod_install.php file.
# Otherwise, please run (go to it in your browswer) that as it's easier.
# If you don't use MySQL, you'll need to edit these queries accordingly
# If you have a different table prefix then change these commands accordingly.
# These currently use the default table prefix.
CREATE TABLE `phpbb_employed` (
`id` int(10) NOT NULL auto_increment,
`user_id` int(10) NOT NULL default '0',
`job_name` varchar(32) NOT NULL default '',
`job_pay` int(10) NOT NULL default '0',
`job_length` int(10) NOT NULL default '0',
`last_paid` int(25) NOT NULL default '0',
`job_started` int(25) NOT NULL default '0',
PRIMARY KEY (`id`)
) TYPE=MyISAM ;
CREATE TABLE `phpbb_jobs` (
`id` int(10) unsigned NOT NULL auto_increment,
`name` varchar(32) NOT NULL default '',
`pay` int(10) default '100',
`type` varchar(32) default 'public',
`requires` text,
`payouttime` int(25) default '500000',
`positions` int(10) default '0',
PRIMARY KEY (`id`),
KEY `name` (`name`)
) TYPE=MyISAM ;
ALTER TABLE `phpbb_users` ADD `user_jobs` INT (20) DEFAULT '0';
INSERT INTO `phpbb_config` (config_name, config_value) VALUES ('jobs_status', 'off');
INSERT INTO `phpbb_config` (config_name, config_value) VALUES ('jobs_limit', '2');
INSERT INTO `phpbb_config` (config_name, config_value) VALUES ('jobs_pay_type', '0');
INSERT INTO `phpbb_config` (config_name, config_value) VALUES ('jobs_index_body', '0');
PRIMARY KEY (`id`)
) TYPE=MyISAM ;
`requires` text,
PRIMARY KEY (`id`),
KEY `name` (`name`)
) TYPE=MyISAM ;
Neni u popisu toho MODu nejaka poznamka, ze to vyzaduje Cash nebo nejaky Points MOD?
uz som dal spat vsetky zalohovane subory, ale teraz ked otvorim administraciu, nic tam neni
poradte, ako mam spravit aby som nemal v administracii celu bielu obrazovku??
Máš přístup k error logu z PHP? Ono se těžko identifikuje ta chyba z bílé stránky.
kliknem na Administracia fora a vsetko je len biele. a neviem co su error logy v PHP
Zkus na konec config.php(před ?>) přidat toto:
Jinak error log je úplný výpis chyb, který si vede server/PHP. Někdy k nemu máš přístup přes administraci hostingu, jinak musíš kontatkovat technickou podporu hostingu.
error_reporting(E_ALL);
Administracia nejde stale, ale pod polozkami hladat a pod. mi nabehlo:
a do teraz to islo dobre, len ked som dal pred ten mod tak to ide zle.
Notice: Undefined index: 8 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 9 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 10 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 11 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 12 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 13 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 14 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 17 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 18 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 29 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 30 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 31 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 32 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 33 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 34 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 19 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 20 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 25 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 21 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 22 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 23 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Notice: Undefined index: 24 in /home/free/tym.sk/n/nelegalne/root/www/index.php on line 420
Warez nepodporujeme. Zamykám.
