stahnul jsem si Last Post Topic on Index mod a ten mi do sloupce "Posledni prispevek" k nicku odesilatele posledniho prispevku a datu odeslani daneho prispevku pridal jeste jmeno topicu, kde ten posledni prispevek je.. Potreboval bych to jeste upravit tak, aby tam byl jenom nick odesilatele a jmeno topicu (tudiz se zbavit toho casu a data odeslani), ale kdyz jsem zkousel oddelat veci typu "t.time" apod, tak tam ten cas zustal, akorat se vyresetoval.. Nevi nekdo, jak se toho casu a data zbavit uplne?
Puvodni index:
<?php
* index.php
* begin : Saturday, Feb 13, 2001
* copyright : (C) 2001 The phpBB Group
* email : support@phpbb.com
* $Id: index.php,v 1.99.2.7 2006/01/28 11:13:39 acydburn Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
$viewcat = ( !empty($HTTP_GET_VARS[POST_CAT_URL]) ) ? $HTTP_GET_VARS[POST_CAT_URL] : -1;
if( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
$mark_read = ( isset($HTTP_POST_VARS['mark']) ) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
else
$mark_read = '';
// Handle marking posts
if( $mark_read == 'forums' )
if( $userdata['session_logged_in'] )
setcookie($board_config['cookie_name'] . '_f_all', time(), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
$template->assign_vars(array(
"META" => '<meta http-equiv="refresh" content="3;url=' .append_sid("index.$phpEx") . '">')
$message = $lang['Forums_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a> ');
message_die(GENERAL_MESSAGE, $message);
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_t"]) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_f"]) : array();
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat('postcount');
$total_users = get_db_stat('usercount');
$newest_userdata = get_db_stat('newestuser');
$newest_user = $newest_userdata['username'];
$newest_uid = $newest_userdata['user_id'];
if( $total_posts == 0 )
$l_total_post_s = $lang['Posted_articles_zero_total'];
else if( $total_posts == 1 )
$l_total_post_s = $lang['Posted_article_total'];
else
$l_total_post_s = $lang['Posted_articles_total'];
if( $total_users == 0 )
$l_total_user_s = $lang['Registered_users_zero_total'];
else if( $total_users == 1 )
$l_total_user_s = $lang['Registered_user_total'];
else
$l_total_user_s = $lang['Registered_users_total'];
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
FROM " . CATEGORIES_TABLE . " c
ORDER BY c.cat_order";
if( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
$category_rows = array();
while ($row = $db->sql_fetchrow($result))
$category_rows[] = $row;
$db->sql_freeresult($result);
if( ( $total_categories = count($category_rows) ) )
// Define appropriate SQL
switch(SQL_LAYER)
case 'postgresql':
$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
WHERE p.post_id = f.forum_last_post_id
AND u.user_id = p.poster_id
UNION (
SELECT f.*, NULL, NULL, NULL, NULL
WHERE NOT EXISTS (
SELECT p.post_time
FROM " . POSTS_TABLE . " p
ORDER BY cat_id, forum_order";
break;
case 'oracle':
WHERE p.post_id = f.forum_last_post_id(+)
AND u.user_id = p.poster_id(+)
ORDER BY f.cat_id, f.forum_order";
break;
default:
FROM (( " . FORUMS_TABLE . " f
LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )
LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id )
break;
if ( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql);
$forum_data = array();
while( $row = $db->sql_fetchrow($result) )
$forum_data[] = $row;
if ( !($total_forums = count($forum_data)) )
message_die(GENERAL_MESSAGE, $lang['No_forums']);
// Obtain a list of topic ids which contain
// posts made since user last visited
if ($userdata['session_logged_in'])
// 60 days limit
if ($userdata['user_lastvisit'] < (time() - 5184000))
$userdata['user_lastvisit'] = time() - 5184000;
$sql = "SELECT t.forum_id, t.topic_id, p.post_time
FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
WHERE p.post_id = t.topic_last_post_id
AND p.post_time > " . $userdata['user_lastvisit'] . "
AND t.topic_moved_id = 0";
message_die(GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql);
$new_topic_data = array();
while( $topic_data = $db->sql_fetchrow($result) )
$new_topic_data[$topic_data['forum_id']][$topic_data['topic_id']] = $topic_data['post_time'];
// Obtain list of moderators of each forum
// First users, then groups ... broken into two queries
$sql = "SELECT aa.forum_id, u.user_id, u.username
FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
WHERE aa.auth_mod = " . TRUE . "
AND g.group_single_user = 1
AND ug.group_id = aa.group_id
AND g.group_id = aa.group_id
AND u.user_id = ug.user_id
GROUP BY u.user_id, u.username, aa.forum_id
ORDER BY aa.forum_id, u.user_id";
message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
$forum_moderators = array();
$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
$sql = "SELECT aa.forum_id, g.group_id, g.group_name
AND g.group_single_user = 0
AND g.group_type <> " . GROUP_HIDDEN . "
GROUP BY g.group_id, g.group_name, aa.forum_id
ORDER BY aa.forum_id, g.group_id";
$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
// Find which forums are visible for this user
$is_auth_ary = array();
$is_auth_ary = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data);
// Start output of page
define('SHOW_ONLINE', true);
$page_title = $lang['Index'];
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
$template->set_filenames(array(
'body' => 'index_body.tpl')
'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
'NEWEST_USER' => sprintf($lang['Newest_user'], '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$newest_uid") . '">', $newest_user, '</a>'),
'FORUM_IMG' => $images['forum'],
'FORUM_NEW_IMG' => $images['forum_new'],
'FORUM_LOCKED_IMG' => $images['forum_locked'],
'L_FORUM' => $lang['Forum'],
'L_TOPICS' => $lang['Topics'],
'L_REPLIES' => $lang['Replies'],
'L_VIEWS' => $lang['Views'],
'L_POSTS' => $lang['Posts'],
'L_LASTPOST' => $lang['Last_Post'],
'L_NO_NEW_POSTS' => $lang['No_new_posts'],
'L_NEW_POSTS' => $lang['New_posts'],
'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
'L_MODERATOR' => $lang['Moderators'],
'L_FORUM_LOCKED' => $lang['Forum_is_locked'],
'L_MARK_FORUMS_READ' => $lang['Mark_all_forums'],
'U_MARK_READ' => append_sid("index.$phpEx?mark=forums"))
// Let's decide which categories we should display
$display_categories = array();
for ($i = 0; $i < $total_forums; $i++ )
if ($is_auth_ary[$forum_data[$i]['forum_id']]['auth_view'])
$display_categories[$forum_data[$i]['cat_id']] = true;
// Okay, let's build the index
for($i = 0; $i < $total_categories; $i++)
$cat_id = $category_rows[$i]['cat_id'];
// Yes, we should, so first dump out the category
// title, then, if appropriate the forum list
if (isset($display_categories[$cat_id]) && $display_categories[$cat_id])
$template->assign_block_vars('catrow', array(
'CAT_ID' => $cat_id,
'CAT_DESC' => $category_rows[$i]['cat_title'],
'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
if ( $viewcat == $cat_id || $viewcat == -1 )
for($j = 0; $j < $total_forums; $j++)
if ( $forum_data[$j]['cat_id'] == $cat_id )
$forum_id = $forum_data[$j]['forum_id'];
if ( $is_auth_ary[$forum_id]['auth_view'] )
if ( $forum_data[$j]['forum_status'] == FORUM_LOCKED )
$folder_image = $images['forum_locked'];
$folder_alt = $lang['Forum_locked'];
else
$unread_topics = false;
if ( $userdata['session_logged_in'] )
if ( !empty($new_topic_data[$forum_id]) )
$forum_last_post_time = 0;
while( list($check_topic_id, $check_post_time) = @each($new_topic_data[$forum_id]) )
if ( empty($tracking_topics[$check_topic_id]) )
$unread_topics = true;
$forum_last_post_time = max($check_post_time, $forum_last_post_time);
else
if ( $tracking_topics[$check_topic_id] < $check_post_time )
if ( !empty($tracking_forums[$forum_id]) )
if ( $tracking_forums[$forum_id] > $forum_last_post_time )
if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
if ( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] > $forum_last_post_time )
$folder_image = ( $unread_topics ) ? $images['forum_new'] : $images['forum'];
$folder_alt = ( $unread_topics ) ? $lang['New_posts'] : $lang['No_new_posts'];
$posts = $forum_data[$j]['forum_posts'];
$topics = $forum_data[$j]['forum_topics'];
if ( $forum_data[$j]['forum_last_post_id'] )
$last_post_time = create_date($board_config['default_dateformat'], $forum_data[$j]['post_time'], $board_config['board_timezone']);
$last_post = $last_post_time . '<br />';
$last_post .= ( $forum_data[$j]['user_id'] == ANONYMOUS ) ? ( ($forum_data[$j]['post_username'] != '' ) ? $forum_data[$j]['post_username'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '=' . $forum_data[$j]['user_id']) . '">' . $forum_data[$j]['username'] . '</a> ';
$last_post .= '<a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" /></a>';
else
$last_post = $lang['No_Posts'];
if ( count($forum_moderators[$forum_id]) > 0 )
$l_moderators = ( count($forum_moderators[$forum_id]) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
$moderator_list = implode(', ', $forum_moderators[$forum_id]);
else
$l_moderators = ' ';
$moderator_list = ' ';
$row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
$row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
$template->assign_block_vars('catrow.forumrow', array(
'ROW_COLOR' => '#' . $row_color,
'ROW_CLASS' => $row_class,
'FORUM_FOLDER_IMG' => $folder_image,
'FORUM_NAME' => $forum_data[$j]['forum_name'],
'FORUM_DESC' => $forum_data[$j]['forum_desc'],
'POSTS' => $forum_data[$j]['forum_posts'],
'TOPICS' => $forum_data[$j]['forum_topics'],
'LAST_POST' => $last_post,
'MODERATORS' => $moderator_list,
'L_MODERATOR' => $l_moderators,
'L_FORUM_FOLDER_ALT' => $folder_alt,
'U_VIEWFORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"))
} // for ... categories
}// if ... total_categories
else
// Generate the page
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
<?php
* index.php
else
$mark_read = '';
// removing them
else
else
switch(SQL_LAYER)
case 'postgresql':
UNION (
WHERE NOT EXISTS (
SELECT p.post_time
break;
case 'oracle':
break;
default:
$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id, t.topic_title, t.topic_last_post_id " .
" FROM ((( " . FORUMS_TABLE . " f " .
" LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )" .
" LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id ) " .
" LEFT JOIN " . TOPICS_TABLE . " t ON t.topic_last_post_id = p.post_id ) " .
" ORDER BY f.cat_id, f.forum_order";
break;
$topic_last_ary = array();
$i=0;
if (!in_array($row['topic_last_post_id'], $topic_last_ary) || $row['topic_last_post_id']==0) {
$topic_last_ary[i]=$row['topic_last_post_id'];
$i++;
unset($topic_last_ary);
// Filter topic_title not allowed to read
if ( !($userdata['user_level'] == ADMIN && $userdata['session_logged_in']) ) {
$auth_read_all = array();
$auth_read_all=auth(AUTH_READ, AUTH_LIST_ALL, $userdata, $forum_data);
$auth_data = '';
for($i=0; $i<count($forum_data); $i++)
if (!$auth_read_all[$forum_data[$i]['forum_id']]['auth_read']) {
$forum_data[$i]['topic_title']='';
// Define censored word matches
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
// 60 days limit
else
else
$topic_title = $forum_data[$j]['topic_title'];
$topic_title2 = $forum_data[$j]['topic_title'];
// Censor topic title
if ( count($orig_word) )
$topic_title = preg_replace($orig_word, $replacement_word, $topic_title);
$topic_title2 = preg_replace($orig_word, $replacement_word, $topic_title2);
if (strlen($topic_title)>27) {
$topic_title = substr($topic_title,0,24) . '...';
$last_post = '<a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '" title="' . $topic_title2 . '">' . $topic_title . '</a><br>';
$last_post .= $last_post_time . ' <a href="' . append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '"></a><br>' . $lang['by'] . ' ';
else
else
else
Diky
