What happens with image?
default value:causes that images will be optimized - saved as JPGKód: Vybrat vše
<input type="hidden" id="theselect1" name="theselect1" value="o" />
other values:causes that images won't be changedKód: Vybrat vše
<input type="hidden" id="theselect1" name="theselect1" value="n" />
(causes that images will be resized to chosen resolutionKód: Vybrat vše
<input type="hidden" id="theselect1" name="theselect1" value="800x600" />
!!if using resizing this we strongly recommnd to use the following two!!
which causes that resizing only makes images smaller, not biggerKód: Vybrat vše
<input type="hidden" id="nezvetsovat1" name="nezvetsovat1" value="1" />
and
which keeps the aspect ratioKód: Vybrat vše
<input type="hidden" id="zachovat1" name="zachovat1" value="1" />
Will there be an information bar in the thumbnail? (something like 251.3kB 1024x768)
default value:causes there will be information bar in thumbnailsKód: Vybrat vše
<input type="hidden" name="radek1" id="radek1" value="1" />
other value:causes there will be no information bar in thumbnailsKód: Vybrat vše
<input type="hidden" name="radek1" id="radek1" value="0" />
Will my image be public (visible at ImageShock.eu public gallery)?
default value:causes that images will be public - will be seen at public galleryKód: Vybrat vše
<input type="hidden" name="verejny1" id="verejny1" value="1" />
other value:causes that images won't be public - won't be seen at public galleryKód: Vybrat vše
<input type="hidden" name="verejny1" id="verejny1" value="0" />
Will there be views counter in the image page?
default value:causes there will be views counter in the image pageKód: Vybrat vše
<input type="hidden" name="pocitadlo1" id="pocitadlo1" value="1" />
other value:causes there will be no views counter in the image pageKód: Vybrat vše
<input type="hidden" name="pocitadlo1" id="pocitadlo1" value="0" />
What background color will be in the thumbnail?
default value:you can change #000000 to color you want for the thumbnail background (use HTML colors inKód: Vybrat vše
<input type="hidden" value="#000000" name="barvapozadi1" />
full format with or without # character, DON'T USE short css format like #000 or word like black!) to match your forum design
What text color will be in the thumbnail?
default value:you can change #FFFF00 to color you want for the thumbnail text (use HTML colors in full format with or without # character, DON'T USE short css formatKód: Vybrat vše
<input type="hidden" value="#FFFF00" name="barvatextu1" />
like #FF0 or word like red!) to match your forum design
