MOD Title: Points MOD
MOD Version: 1.0.2
MOD Descripiont: Points MOD is modification for phpBB3 boards which adds user points to your board. You can set how much points will user receive for creating a new topic or posting a reply. You can also enable/disable Points MOD for certain forum. Users can transfer their points to other users.
I have created this MOD because there is no simple, working and still developed Points MOD for phpBB3 boards.
For more information about this MOD, please read features list.
Works with: phpBB 3.0.8
Language: English
Authors: Kamahl
License: GNU General Public License v2
MOD Format: MODx
Features list:
User Features:
- user will receive points for creating a new topic and posting a reply
- if post or topic is deleted, it will take away points from its poster
- display points in viewtopic and user profile
- possibility to transfer points to another user
- if admin set moderator permission, moderators can change user points
ACP Features:
- enable / disable Points MOD
- enable / disable Points MOD for certain forum
- set the name of your points
- set how much points will user receive for creating a new topic
- set how much points will user receive for posting a reply
- enable / disable transfers among users
- enable / disable transfer notification by PM
- enable / disable writing a transfer message
- enable / disable displaying The richest users on index
- add, remove or set points to certain group
- reset all points
- permissions to administrate Points MOD, use transfers and change user points
Screenshots:
http://www.phpbb3hacks.com/obrazky/points/screen1.png
http://www.phpbb3hacks.com/obrazky/points/screen2.png
http://www.phpbb3hacks.com/obrazky/points/screen3.png
http://www.phpbb3hacks.com/obrazky/points/screen4.png
http://www.phpbb3hacks.com/obrazky/points/screen5.png
http://www.phpbb3hacks.com/obrazky/points/screen6.png
http://www.phpbb3hacks.com/obrazky/poin ... screen.png
Donation:
Send a donation
Download
http://www.phpbb3hacks.com/viewtopic.php?f=76&t=518
[RC] Points MOD 1.0.2
Kamahl
Re: [RC] Points MOD 1.0.1
vydana verzia 1.0.1
Kamahl
Re: [RC] Points MOD 1.0.2
vydana verzia 1.0.2, opravena chyba pri poslani Points inemu uzivatelovi
